890man
Well, 290K and it finally happened. I pulled the spark plugs to do a compression check starting with #1. When I cranked it over, I heard a loud pop. When I went around to the front there was fluid everywhere. Im in the driveway but the fluid was on the floor of the garage and sprayed on the side of the house a good 12 feet up! I placed a white towel over the plug holes and cranked. The spot over #5 had a greenish look and smelled sweet. Coolant. Damn.
I want to prevent rust while I figure out what to do so I was thinking of:
Draining the coolant
putting the plugs back in and running it for 30 seconds or so to dry it out
Pulling the plugs and adding a bit of oil to each cylinder
Cranking it over to distribute the oil
Then draining the contaminated oil from the pan
Does this sound like a viable plan?
