Buy Sell Trade
Anyone need some 33s?
Cooper ST Maxx 285/75R16
4 @ +/- 11/32"
Spare was never put into rotation and has 0 miles - 18/32"
$500
I have a used Analytic Systems BCD600-32-12 Battery charger for sale such as explained at this retailer: Analytic Systems BCD600-32-12 DC/DC Charger
The manual is here: https://www.invertersupply.com/media/data/bcd600_manual.pdf
I fed it 24V off my BJ74, hooked it up to a spare battery and turned it all...it powered up and started charging the battery.
If someone has a 24V truck and is looking to charge a house battery for 12V needs this would be great. That's why I have it, but I do not see myself putting it to use.
I can supply a good used AGM battery with it. It is an Alliance AE9A31.
Have some used 8AWG wire that we can work something out with too.
$300.00 Charger OBO
$100.00 Battery OBO
Plus any ride
I have some leftovers I will not be using with my sub-tank installation for anyone looking to do a factory subtank install on their 80 series.
SOLD - $150.00 - Overhead sub-tank fuel gauge/altimeter in grey.
$350.00 - Solenoid/fuel pump setup, with brand new harness (that goes between the main tank, subtank, solenoid, fuel pump and sill harness)
Hooked up power to the solenoid/fuel pump and it pumped fuel.
Plus any ride.
View attachment 1678513 View attachment 1678514 View attachment 1678515 View attachment 1678516
If this falls through I'm interested.
@Ringwraith we will confirm later this week when you pick up the overhead console. Will be an easy check as there should be a vacant connector under the left side sill where the main tank harness connects, goes through a rubber grommet and into the main sill harness, as well as a vacant connector under the body at the rear of the truck, where the subtank empty and float level signals hook up. On the JDM's I have looked at they were not there. In your situation with non stock and custom it might be easier to just build your own harness anyway. But will confirm with yours.
@Gil as above, will confirm later this week, but in either case the fuel pump/solenoid is available.
FOR SALE
OME 861/862 stock height set for 80 series, used, some surface rust.
OME 60018/60020 Nitrocharger Sport Shock front and rear set.
All for $200. Local pick up.
Truck only uses for summer camping trip.
Thanks.
FOR SALE
Toyota factory hitch from 97 FZJ80. $100.
Rear bumper corners, excellent condition, purchased new from Toyota dealer couple years ago. $100.
Recently upgraded to 4x4labs rear bumper. Thanks.
SOLD. Thanks.
FOR SALE
Thanks.
Tembo Tusk load spotter fridge slide.
I've never used it and its still newish. I have modified with holes for lightening it up see pics below. I mocked it up for install and its shows wear on the pivot points.
These are no longer available. I purchased it 2014 and it was about $1100 US . Never going to use it so the first $700 CAN takes it. I did not purchase the version with the cutting board.
video of it here:
I can bring to cruiser days
You should buy it and sell the arb one. The tembo will work better with your rear deck
I'm on the hunt for a pair of rear brake backing plates from a '94 - '97 FJ80 so I can upgrade my 1990 HDJ81 rear brakes to more readily available consumables...
Any leads would be appreciated!
Located on the Island...
Was off one number on an order and got the incorrect bushings. Not many RJ/LJ's around but if you know anyone...
Two RJ/LJ front panhard bushings for sale. $25.00 each.
Hi Guys, I just imported a beauty 96 LX 450 from California. Got it across the border today and went straight to inspection.
It went very well but there's a crack in the driver's side front turn signal (long thin and orange below the headlight) I nerd to replace it to pass my VI. Does anyone out there have one kicking around? Even to borrow for now and return post VI?
I'm stoked to finally have an 80 and stoked to join the community you have going here.
