Built on rock slider question.
Walnut creek ca
Hey everyone, just in the look for some rock sliders for my fj60. I know there's bolt on and weld on types. The weld on are obviously stronger but I don't really like to weld anything into or on my frame which is why I may consider the bolt on. My only concern with the bolt on sliders is the metal tubing for the break lines/ and wires I have on the inside frame of the passenger side(in pic). What will happen to those? Should I move them? Or will they be ok with a U-bolt around the whole frame?
Thank you for the help!
Ps. I like the sliders from "white knuckle off road" the have a bolt that goes around the frame.
They most likely will need to be unbolted from the frame during the install, then a spacer put in between the hoses and frame to prevent wear. The u bolt around the frame would crush all the lines if they were not moved out of the way.
those are the bizniss^^^
bolts ons work fine....I've had the entire truck weight on mine multiple times...
