georgebj60
Sorry, I'm not a expert, but it doesn't sound right to me. Beautiful motor though!
Agree with this—the sound doesn’t go away when you put your hand there, it just stops resonating against the sump. It’s acting much like the body of an acoustic guitar or a violin and amplifying the sound.Seems as though something is resonating...check carefully around the motor. Must be something insignificant. Sounds almost like an air popping sound of sorts.
It sounds like when u put your finger in a beer bottle and you pop it out. Had you coolant in it when u ran it? Perhaps the water pump impeller, something to that effect. Doesn't sound metallic, so I don't see how this can be something that could damage your newly rebuilt engine by runing it again to try to identify it. Check oil levels, pull the valve cover to see if it gets oil to the top.
This is baffling!
I doubled checked everything under the rocker cover, it looks like its getting fresh oil and nothing is stuck or out of place. The noise also sound like its coming from the front of the engine from the timing gear area.At this frequency I’m thinking lifter, push rod, rocker, valves. Oil pump relief v/v (usually rattle not hammer sound).
Like said before, might be somewhere else and resonating on oil pan.
I'd stabilise that stand and run it again.. given it changes when your hand is against the sump I dont think its anything serious.
No problem, send it overBeautiful. Nice work. When can I send mine over? Haha.
