Build Plans (and questions)
Tulsa, OK
Website
www.cardomain.com
Done alot of research and I think I have it narrowed down. Any input would be welcome.
Looked at the MAF 2"-1" OME kit and kinda dig it. It utilizes 850/862 and allegedly sits "level". If it's low in tha ass end I can always go w/packers. This way I wouldn't have to raise the front (possible driveline vibes) if I used 863's in the rear.
I did a buddies `94 w/850-863 and it was "stinkbug" city. That's fine for many, I just perfer a more level stance.
Shocks? Should I stick with OME or go for Bilsteins, or somthing else for that matter?
Going 285's, and a non-winch ARB (later)
What yall think?
KR
You should be fine with that suspension, as in "no stinkbug" before the ARB (if the cargo area is not carrying tons of gear). Might need to level it out front (10-20 mm) after the bumper goes on. I have OME shocks and they are world's better than stock, but can't speak to them vs. the Bilsteins. Lots of others can (and probably will :)). As for ds vibes, you shouldn't have anything to fear at that height unless the ds is already toast.
Good luck!
one would think that if you're level before you load up the cargo area, you would be saggin and draggin' when fully loaded on the trail.
if you begin with the "stinkbug" stance before loading up the cargo area, then one would think that you'd ride somewhat level once fully loaded (with gear) on the trail.
:hhmm:
Get the OME shocks for the OME kit - that's the only reason to buy OME: it is designed as a kit.
This coming from a guy who heavily prefers Bilstein to OME shocks and high end springs to OME springs :flipoff2:. OME's base kits do a nice job, all you can realistically accomplish is some de-tuning on your dime.
