Brown Davis tank installed
Have you got any pictures of the tank in?
How much does it hang down? I am deffo thinking that a little bit of a body lift will be a good idea with a long range fuel tank.
Yeh, I'd like to see this too.
Got any pics showing the tank fully installed? Do you have any concerns about the tank hanging below the frame rails?
Here we go.
You can see the tabs of the angle iron that was welded across my frame when I got my truck. It had to go for the tank to go in, haven't had time to cut them off.
You can also see that where the tank bolts up in the front I didn't remove the bolts that hold the fuel return line. Lazyness on my part.
The install wasnt that bad. Trans jack was better than using a strap to hold it like i did the first time.
Just got back from my folks' house. 325 on this tank. Sitting at 3/4 of a tank. Im guessing i used 33 galons, so i must have bent the bar too much. Im not picky, so ill probably just live with it. The guage will serve its purpose, and ill get used to it.
