Broken stop on knuckle..ideas?
North Mississippi
Attached a pic of the broken knuckle turn stop...I'm thinking of going without or welding a nut and inserting a bolt. Prior owner must of done some serious off road thrashing...
Also - is this hub (pic attached) still good with all the dents on the lip?
Thanks
Knuckles are cheap. Replace it . A weld probably wont hold if you have them adjusted correctly.Might save some time in the end.
And while you're at it... convert to disc brakes.
hard to tell from the pic, but the hub looks fine. mine are beat too, but as long as they seal and all the bolts go in, you're set.
course if you upgrade to discs, you'll get new hubs anyway and won't have to worry about it :D
Thanks sir Nukemelon & Tootall........knuckles on order......I'm sticking with the drums for now since I just purchased all da junk for them. One day perhaps I will graduate to the big time disc brakes...for now...college funds are king.
Is it too late to cancel your order?
I tried to give my Drum stuff away when I converted to MT.
I'm sure there are a few guys that will have some sets available this winter :D
Ignore those disc brake convertees from the dark side! Your drum brakes are fine as long as you keep them adjusted properly. Of course that means crawling under the Cruiser once a month... :frown:
I call BS on the once a month i went 10k with out an adjustment this last year.
All depends on your driving style (On our Nissans my wife can go through a set of pads in 30K, I can get 80K. ;) YMMV :flipoff2:
If you have a light braking foot, know how to down shift, and never drive in mud, then sure, I can see going 10K+ without adjusting the brakes. I would personally adjust them more often than that just to keep that extra edge. I HATE pumping brakes. My post was more an on going joke here on Mud about the biggest complaint given for drum brakes: ADJUSTING THEM...
[...snip...] here on Mud about the biggest complaint given for drum brakes: ADJUSTING THEM...
The biggest problem is that they are CRAP. They have no wet stopping power at all, require constant maintenance and are excessively expensive to replace parts for.
A home brewed disc conversion is cheap. Can probably do it for around $250 if you're good with a wrench and have good used parts to work with.
Nice healthy debate...I think... Hey, since when does a quick hydralic lift and adjust to a caliper become an inconvenience for a true landcruiser owner? ... I thought we all were suppose to be able to handle a little inconvenience...you all have opened my eyes...but the final analysis...stay real...stay drums!!! (plus it brings back fonder memories of my 70 nova & 66 dodge dart)....
Later
true after water crossings you need to warm the brakes back up and drive off the water but if you know it going to happen and see it coming then its not a big deal
I have a set I'll give away just to get them out of my garage. 1975 FJ40 knuckles drums, warn hubs, the whole shebang. I think I still have the course spline birfs and inners too.
Mini Truck axle from the junk yard $225
New brake flex lines, re-built calipers and new pads around $75
So yeah about $250 to $300.
I drove my 40 for many years with drums, even when properly adjusted they were not as nice as disk. It's hard for me to describe it but the disk have a better "feel" when doing a hard braking manuver. IMHO the front disk conversion was well worth the time and effort.
Yeah, I wanted to keep it stock and spent around $1K replacing all drum brake parts: brake booster, master cylinders, all 8 slave cylinders, all flexible brake lines, 4 drums, 4 set of pads, accessories, I used all brandnew OEM parts from Toyota dealers. It needs lots of adjustments to stay straight, it would stop nicely but on steep inclines, I had to stand on the pedal...
And I converted the truck to all Toyota disk brakes with 4Runner V6 calipers in the front and FJ60 calipers in the back, now it works awesome and I kicked myself for wasting money keeping the drum brake back then.
