Was wondering if anyone has the part number or preferably a link to the 1fz injector connectors. Several of the lock tabs broke when trying to remove them.
Can't help too much at the moment but have you checked here?
http://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
I did. But on this particular connector there isn't a "ramp" to allow the tool to be inserted to release or compressed the tab and lock on the pin.
Dan,
Did you try removing the red rubber gasket? Maybe the pin lock is underneath that. Toyota always uses a locking mechanism for its connectors. The lock has to be loosened (not necessarily removed) so that you can release the contacts using one of your tools shown in post #8, or they may require something sharper like a dental pick depending on the size. But first find the plastic lock device.
You'll get a laugh out of this ... found it in the PDF you linked: Toyota's directions: "HINT: ... Please construct and use the special tool (to remove the pin from the connector". So, per their drawing, the pin removal tool is 1mm thick (!) and tapers to .2mm at the front of the tool's ramp. Right.
I sure didn't want to try to make a shank of my own. Send one my way. Just ordered it. Thanks, Joey!
