Breakerless SE - Electronic Ignition Conversion
iPad
Has anyone done this? Wondering if this can also be an option alongside Pertronix conversions especially in early small cap distributors? This unit seems to work with stock coil and stock single wire connection.
Here is an article - https://www.hemmings.com/magazine/mus/2017/05/Immaculate-Deception/3750840.html
To me this is nice, but, for FJ40 the pertronix does the same thing. And is proven. I am using it on a 1969. Best change I ever made for the engine, Pertronix.
I am exploring this option only to keep stock appearance I.e. using stock Toyota coil and single wire. Apparently this kit also dosent blow ignition should you leave key in switch at on position for long time. I heard the early Pertronix kit had some issues and not sure if Pertronix 2 fits in small cap distributors.
I am using Pertronix 2. It has safeguards for ignition on burnout. Says on website as well. I am not sure what small cap you mean, but my distributor is all original , and it is a small cap to me. I gave them the distributor number and they send the kit.
http://shop.pertronix.com/ignitorconversionsbydistributor?brand=Nippondenso#auto
I’m sure it could work if they tooled one to fit a landcruiser distributor. If not, I don’t think it would be worth making it work. I’d not want to be the guinea pig to see how long/well it’ll last in a dusty, dirty, hot, and wet environment. I’ve had an F keep running while fording a stream over the front fenders without missing a beat... a couple weeks later it wasn’t running so well, turns out the distributor had filled with water and there was a water line 3/4” up the inside of the cap. By all rights it shouldn’t have kept running... but with points, wd40 in the cap, an MSD 5, and a large horseshoe... it kept on going.
Getting to the point, how well sealed is it? Would the optical sensor still work under water? Would it fit in a 40 distributor?
