Break line replacement
Boston
Website
www.burnmachinefilms.com
A leaky break line was found on my 94FZJ so I had the Toyota dealership look into replacing all the lines because of the rust - A quote of 2500 or more for parts and labor was given.
Is this a common figure for lines only
or should I just take this on myself ?
I've done the lines on my 60 before but they seemed slightly less complicated ?
Any input would be greatly appreciated
I had all mine replaced with OEM parts by local garage, except on hard line they made on the rear axle. I think it cost me around $400 for the labour. The long hard lines that run along the frame were quite inexpensive from the dealer IIRC.
The lines are rather inexpensive. Maybe confirm the cost of just the lines and unions(if needed).
The labor is probably what causes this to be so ridiculous for two reasons:
1) Most of the time these are calculated by the Flat Rate manual and the Service Writer(the guy who makes the quote) doesn't take time to think about common labor for each task. For instance, replacing one of the lines from front to rear may be a 2 hour job. Replacing the other line is also a 2 hour job. They count it as 4 hours, even though it only takes 2 hours to do both at the same time. Ask them to make sure they aren't double counting these sort of tasks.
2) Some of the lines "require" removal of other parts to make the job easier for the mechanic. This often tacks on extra time for removal and re-installation of those parts.
You should be able to do this yourself, though it isn't easy and takes some time. Keep in mind that when the lines were installed at the plant, nothing else was in the way(like the engine and fuel tank) so they were REALLY easy to install.
Hope this helps.
Thanks guys! This helps a lot! With a new house, kids and no time I'm letting the dealer handle this. It's down 1800.00 flat so it's Raman for dinner-
Something to consider if you do this yourself is that you don't have to make single line runs. You can cut the lines into manageable pieces and couple them together.
Why are not all aftermarket lines the new Plastic Coated type.
I'm sure they could run same CNC bender program with slightly larger diameter line and add a set amount to each radius.
Kaizen.....Hi-Ya!
Be aware that most dealerships charge way over $100 labor. If you can't manage it on your own , it may be much less $$ to find a good old repair shop
the lines are readily available and the ones running along the frame rail are kind of a PITA. I use factory line as they are really cheap for what you get and use a good pair of diagonal cutters to cut the old lines in pieces and slide them out of the frame clips instead of trying to pry them out.
If the lines are bad then the LSPV is likely toast as well. Good luck with the repair
