brazing
lebanon,pa
Website
www.facebook.com
i almost hate to ask this.....being the steel work i'am and an all.....
i noticed a weeper on the rad this morning.
tank is brass
the leak is about the middle of the tank, up high on it(probably won't even need to drain any water).
so after digging around the house, i was able to come up with an old sears brazing set, mapp bottle(almost full) and a few brazing rods with the flux on them(mostly).
the area i need to cover is less then the dia of a pencil lead. it's enough to make a little green "puddle" on the upper tank flange, after a spin around town.
do i need any extra flux(paste).
i can't say i do alot(or any)of brazing. copper soildering yes.
brian-hanging head in shame
The flux on the rod you found is chipped at each end of the rod, right?
While it'd be best to have some flux beside that, you should be able to get by by cutting the rod back to where there's a good flux coating.
It's like soldering where you heat the work enough to melt the rod and that'll be hard to do on a brass radiator tank. Solder it.
When I first read your post it didn't register what you want to fix. Pinhead's right, you could really make big holes trying to use brazing heat.
soldering it is then. i've gone this long without brazing...why start now?
never even though if just doing that....
so do i want acid core or rosin(sp) core?
Acid core, rosin core is for electrical. Clean the crap out of it and I would prep it with some acid flux even if you are using acid core solder. Oh, you are going to take the rad cap off so as not to create any pressure? Good call.
GL
Ed
Either will work, acid might be the book answer.
I like brazing for small repairs that you'd want to tig these days.
The torches slow me down and I've never lost the feeling that I'm watching something magic when I melt a puddle very gradually, with the work changing colors back and forth with the slightest move of the flame. I get lost behind goggles for a little while.
GL
Ed
we have tons of solder at the shop, and i could'nt tell you what kind it is:whoops: ..
well aperantly it's acid core, what for the copper pipe and all......
of course i would take the cap off.:cheers:
i've already had to "fix" leaks with the pressure on. not pretty but i got'er dun.
you can't see the leak in this pic, but you can see the location(in side the green sharpie mark just above the corner).
as of this moment i'm just going to wait till tuesday, and fix her at work.
i just hate the smell of coolant.
Honk, I know what you mean on the flame thing. My wife has a little torch (Blazer) for carmelizing Creme Broule and I love soldering with that thing. It is butane and has an adjustable flame, very pinpoint, very hot.
The inner darker blue part is called the reducing flame and if you can keep it positioned over your work, things stay much cleaner, i.e. no oxidizing.
Bri, go ahead and fix that prick!:D
Ed
I've ordered from these guys before and their stuff seems to be of the highest quality. Check out the videos of the repairs to radiators. I think that you'll be surprised. I'm not affiliated (other than a customer) with these folks.
Best regards,
By the way...the repair to a radiator tank would be made with the Muggy Weld super alloy one and a propane torch. Check out their video on such a repair.
Best regards,
Best regards,
:confused:
you mention "them" yet don't tell me who "they" are....
