Brake drum swapping--front to rear--troopies and pickups.
It appears that from Sept. 1975-July 1980, J4-series trucks that came with front drums got a 3-inch finned drum (43512-60020) for the FRONT axle.
The FJ45 and HJ45 also used this same 3-inch finned drum on their REAR axles--and can be swapped, front to rear, as Dan suggested.
Then beginning in August 1980, a different, non-finned but 3-inch, drum (43512-60030) was used on J4-series FRONT axles.
However, a narrower non-finned drum (42431-60020) was used on the REAR of the FJ45 and HJ45/47, including the full-floater.
Because of profile differences on the edges and lips of the two drums, these CANNOT be swapped front to rear; up to the end of production, April 1986.
Not sure if changing-out backing plates might be possible, but simple drum swapping is out for the later troopies and pickups.
First photo is 43512-60030 front drum 8/80 up (Drum "A") side profile.
2nd photo is 42431-60020 rear drum 8?80 up (Drum "B") side profile.
3rd photo is Drum A depth, nearly 3-1/2 inches.
4th photo is Drum B depth, exactly 3 inches.
5th photo is Drum A with a deeper outer face recess.
6th photo is Drum B with a much shallower face recess.
