Braking problem continued
Fallston, MD
So, I bought my 1991 with no brakes. The PO had a few rusty metal lines that he cut and replaced with compression fittings. I replaced the metal lines so that the brakes would actually hold under pressure. The PO said he had a shop replace the master cylinder, because after the line repair, he couldn't get a pedal. They said they didn't have any luck with the first master cylinder, so they got another new one from the company under warranty.
I wasn't getting any fluid to the rear, so I went ahead and replaced the lspv with a summit proportioning valve, capped the line at the front 3 way tee. So last night we try bleeding the brakes and nothing, no fluid to the rear brakes, very little to the front. We had previously taken the lines off the master cylinder and bent metal lines back into the master and bled it that way. I am not sure if the shop before me bench bled the master.
So after not getting fluid my friend had me pumping the brakes while he put his hand over one port on the master with the line removed. He said it was barely pushing his finger off, and when I let off it was pulling vaccum on his finger. According to him, the pressure seems low and the he thinks it shouldn't have any vaccum. We are thinking of getting a new master cylinder, but I am at wits end with this truck, it has been over 2 months and I still cant drive it.
So should I try and bench bleed the master? Or get a new one? Any recommendations on what brand? I have already dumped a good chunck of change into this thing, so dealer parts aren't a option.
Thanks,
turbodrabbit
Doesnt this have a booster as well for the pressure. I am not familiar with 91's, but my FJ40 2FE did, so I would assume this does.
It does have a booster, but when you start the truck the pedal goes right to the floor. We haven't been bleeding the brakes because I have a chunk of my y pipe missing, so the thing is loud, as well as the carbon monoxide.
Bleed with the engine off...
Bleeding it with the engine on is far easier than bleeding with the engine off, but you can do either.
The issue isn't with how I am bleeding it, the issue is I am not getting any fluid. And should the master be pulling fluid back (aka vaccum) when you left off the pedal?
You have had a lot of problems and I hate to say it, but it's going to be difficult to say what the problem is.
It sounds like your braking system has not been maintained at all. If it were my truck, I'd find a donar truck and pull the master cylinder, brake booster, and hard lines. Buy new soft lines. Replace all those, then proceed from there.
It seems like you have a lot of different things going on that's not stock, so I would revert them back. The only thing I would not have as stock is the LSPV, with disks in the front and drums in the rear, the rear brakes will have a very difficult time overpowering the disk brakes, so oversteer isn't too much a concern. I would replace the LSPV with either a manual proportioning valve or a simple T.
If you aren't getting any fluid to the rear I would suspect a kinked/blocked line or no pressure. Kinked/blocked line is easy to test, undo a connection and see if it squirts when someone presses on the brake. You can also hook up a pressure gauge at the same time to determine how much pressure you are getting at that point. Work your way from the back foward, and see what you got going on.
If you've bottomed out the brake pedal you can damage the master cylinder.
bench bleed the thing; it'll take a half hour after the 12 or more you should spend replacing all the lines. Like Ebag said, sounds like you are dealing with a lot more than just a master cyl/booster.
The MC should vent/pull fresh fluid from the reservoir when the pedal is released. When a MC is replaced the booster push rod should be adjusted or confirmed to be the correct length for the new MC. If it's too long the piston can be held slightly depressed, covering vent/fill port. This can cause the problem your seeing.
and also the vacuum/negative hydraulic pressure will allow the brake pistons to travel back and keep the pads from rubbing.
