Brakes...argh!!!!!!!
Try adjusting the rear shoes with the drums off until you can just barely slide the drums over the shoes. Then tighten the shoes more until they lightly drag as you turn the drums by hand. See if that helps with the pedal. Drums have to be really tight (but not so tight they get blazing hot on a test drive).
And after you get your pedal back, you will need to readjust the drums within 100 miles as the shoes bed in, but this should only be a few clicks per side on the adjuster wheel.
I have to double pump my brake.
I’ve replaced everything and upgraded the MC to the 80 series.
ive most recently adjusted the rear drums by working the mechanism from the rear little panel which worked a treat, however i think it reached its maximum adjustment.
Nonetheless this worked for about an hour, after using the handbrake when I parked it, I heard and felt a scrap sound, and then noticed the handbrake and brakes were back to how they were before. (Requiring a double pump to work)
ive bled the brakes a dozen times. I have no leaks, new rear shoes and pistons.
New print pads, new MC (which I thought would have helped it )
blahhhh
When you replaced the master cylinder, did you bench bleed it, adjust the booster push rod & adjust/check the brake pedal?
I didn't hear you mention replacing the brake hoses. As those rubber parts get old they swell/deform under pressure and contribute to spongy pedal feel.
The rear brake adjusters can be finnicky, but taking them apart, cleaning & lubing can do a lot to make them work properly.
The 84-90 chassis/body FSM covers all the adjustments I mention & has a troubleshooting section that covers different noises, definitely worth procuring.
