Are there over the counter stainless lines available yet or is everyone still getting custom fittings on the ends?
Anyone try the EBC Green Stuff 6000 or 7000 brake pads?
Hey Mudders
I just realized its been a year with the BBK on Atilla (The Hundy...)
Still like the kit, still recommend it if you have the $$$ to spend. It has made the driving experience a lot better for the way I use my truck.
Cheers
Chris
I agree with hoser on the Stoptechs being a notch or two above in overall quality of construction.
I'm now on my third set of SS brake lines up front I can tell you the current Stoptech lines are much better constructed and worth the coin.
They should reduce or eliminate the wear issues I had with the previous 2 sets (1-came from a local clutch and brake shop...installed years ago; the 2nd set came from NAPA; and the current are Stoptechs that came with the BBK).
I installed these and they've been great so far.
http://www.ebay.com/itm/290709132462?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Has anyone tried StopTech's cheaper sports kit? It comes with the SS brake lines but doesn't include the 5th line from the frame to the rear axle.
http://www.autoanything.com/brakes/73A5865A0A0.aspx
The Goodrich SS lines say for 98-02 with out VSC. Do the SS lines affect the VSC?
How is the noise? I just got the Jonesys's rotors and ceramic pads, wondering how the noise is under braking...
none so far.How is the noise? I just got the Jonesys's rotors and ceramic pads, wondering how the noise is under braking...
The performance is a lot better than stock. Most companies' rotors are made overseas and finished in the US. If they were just as good as OEM, then it the price was a good buy, but we'll see how they perform over the long haul.I've been eyeballing these for a few weeks now and hope to have em installed before GSMTR.
I had these on my old 100. Sandiegocruiser has them too. He said the squeak a lot when dusty. Mine also squeaked at low speeds on the street. I'd try their rotors with OEM pads.
There was a big improvement in fade from stock.
You are probably thinking of the Goodridge lines. AFAIK, there is only one type of Stoptech design. You will still need to get the 5th (and 6th) brake line elsewhere.Does anyone that ordered the Stoptech SS braided lines have an order number they can PM me so I can point them to the correct size and connectors on either end?
