Thank you for you thoughts.
My theory is that if there is air in the plug chamber and hollow part of the blue piston - the rear brake pressure will push the piston towards it. as it should per describtion of the function - but still I dont like the fact of air in the system.
However, I have managed to put it back together immersed and will try it tommorrow once bled properly - my first test drive just now showed still air in the system - so I have to do it again.
I believe that the brake fluid can't run out once the plug is closed as the cup seal in the plug itself is closing off that chamber.
By the way - all components of my valve were in really good condition, I have just replaced the two o-rings.
