brake problems
hey guys,
what would the problem be if i had brakes that were a bit on the mushy side.. and while i was stopped, the pedal would slowly fall and lose pressure and car would start moving forward (unless you step on the brake pedal harder)?
i bled the brakes and the fluid level is topped off... maybe i need to bleed it again??? i hope it's an easy fix and not having to replace the caliper or brake cylinder assembly...?
Sounds like the master cylinder needs repairing or replacing. When the pedal sinks under pressure it is usually caused by fluid leaking past the cups on the piston.
Have you checked all of your brake lines for leaks? I would also check all the connections (brake lines) to make sure there are no leaks apparent.
I'd try bleeding again starting at the rear brakes and working your way around.
If that doesn't work, likely Master Cyl like the others said
thanks guys...
any idea how much brake master cylinders cost?
it's pretty much the brake booster right? the giant can against the side of the firewall?
The master cylinder is the metal and plastic part that holds the brake fluid.
First, try bleeding the brakes again. Since you don't have a lot of DIY experience, it is possible that you didn't get this right the first time. It isn't terribly hard but tiny "mistakes" will result in having to do the job again. Read up on it first. One key thing to remember is not to pump the brake pedal to the floor. Put a wood block under the pedal so it won't go to the floor. The reason is that the MC cylinder must stay in its "normal" operating range or you will risk messing up the seals. If you mess up the seals then you will have to replace the MC, bleed it, and bleed the entire system again.
The other keep thing to remember is you want NO AIR (none, nada, nothing at all) in the system. This takes good discipline in keeping the MC full, keeping the bleeder valves open and shut at the right time, bleeding in the proper sequence, bleeding the LSPV as part of the system, keeping the hoses in the brake fluid, etc. If you failed to keep brake fluid in the MC while bleeding the wheel cylinders, then you will have to bleed the MC.
-B-
from toyodiy.com depending on which one you need, this is list price. pm/talk to cruiserdan for current pricing
47201 CYLINDER SUB-ASSY, BRAKE MASTER
47201-60550 FZJ80; W(*66) € 271.80
47201-60570 FZJ80 € 301.42
