Brake problems (help)
southern Illinois
I am trying to bleed my brakes on my fj40. My problem is that after trying to bleed every line, I still have no pressure on the first or second push of the pedal. If you pump the pedal a few times it will finally start to build some pressure, but then if you leave your foot of the pedal for a few seconds and push on it again it will have no pressure anymore. I have no leaks that I can find and my fluid is not draining out of the reservoir at all. Does this mean that my master cylinder is bad or what? Any help would be greatly appreciated.
Thanks.
Did you adjust the brakes? If they are very far out of adjustment, the return springs on the shoes will compress the wheel cylinders and return fluid to the master which then takes 2-3 pumps to push the shoes back out. This is all assuming that you still have drummies all the way around.
HTH
Ed
In what order are you bleeding them in. If you have drums all the way around and the single cylinder I believe I started on the passenger side front then PS back, then DS back and DS front. I believe that should help. Also you may have a bad bleeder valve, although if that were the case then you would be leaking fluid. But you could still have someone press on the brake as you went around and tested to see if you feel any air. One way to test your adjustment is to jack up the front off the ground spin the tires and press to see if they stop. Someone told me once you should get one full revolution before it stops on it's own. Not sure if this answers your question or not but if ya have any more just pm me, I have a 68 fj40 with all drums. It's a PITA. Later Chuck
HTH
Ed
X2 You need to adjust them.
Assuming your drum brakes are in adjustment, I would suggest to benchbleed your mastercylinder. I had the same experience and it solved the problem. If this doesn't help, the MC is probably bad. I bought a gauge kit from SSB and meaured pressures directly at the taps to troubleshoot a bad MC.
If you mean that you put a light pressure on the pedal and it gradually goes down That IS a classic indicator of a bad master cylinder.
As to bleeding:
Did you change any part of the brake system to bring about this need to bleed? A master cylinder, for example, is best bled on the bench before installation because it's easier to do a complete job. I would even remove it, if I had just installed it, to do a bench bleed before going out to the wheels. A poorly bled M/C can cause that much grief.
If no change has taken place and the system worked fairly well before you began to fix it, look to your bleeding technique. You should start with drum brakes adjusted to where you just hear the shoes touching the drums as you rotate the drum. It's nice to bleed each cylinder into a jar of fresh fluid through a hose as that allows the observation of air being pushed out and it prevents air being sucked back in when the pedal is released with the bleeder still open.
Failing that nicety, have your helper (GET A HELPER) push the pedal down several times to the command of "pump!" Stop the pumping with the command to "hold!", at which point the helper should apply firm pressure to the pedal until commanded to "release!" (coming up). With the pedal firmly held, crack (this is a quick open/close action - you don't want to leave the thing open for more than a split second because the pressure will dissipate if you do) open the bleeder furthurmost away from the master cylinder (usually the right rear). JUST CRACK IT AND IMMEDIATELY CLOSE IT! Now you can command "release!" Your helper must be instructed to exert unrelenting pressure on the pedal until commanded to release - NO EXCEPTIONS.
You should have either 1)heard a funny little 'spitting' noise while the cylinder was open. or 2)seen fluid shoot out all the way across to the other side of the vehicle. The spitting is air escaping under pressure and if you heard that you should repeat the ENTIRE procedure, including the pumping to hold, until you achieve the second result at that cylinder. Continually be mindful of the fluid level in the master cylinder and replenish it often - both sides. IF YOU ALLOW THAT LEVEL TO GO DOWN TOO FAR YOU RISK PUMPING NEW AIR INTO THE ENTIRE BRAKE SYSTEM - it's very important, you see.
Once no air is coming from that cylinder move to the other rear cylinder and repeat all of the above. Continue until all cylinders are free of air.
If, after all of that, you still have a low pedal then it's time to make adjustment to the master cylinder pushrod. I've assumed no change to that so this shouldn't be needed if it hasn't been meddled with before now.
Use adults as helpers. Young children are unreliable exerters. :D
OK, Thanks For all this wonderful information. I will try adjusting the brakes and checking my push rod. My biggest problem is that I have all newer components on my 1969 fj40, disk brake front, drum rear, and fj60 brake booster and master cylinder. Would most of you say that if my brake master cylinder is pumping fluid to all the calipers and when i crack the bleeder valves fluid squirts out, that my master cylinder is not faulty and that it is something else creating the problem. When I pump up the brakes it will hold the pressure and will not gradually lose it. It is that when I leave off the pedal for a few second and then push on the brake it will have no pressure and the pedal will easily go to the floor. I just don't want to buy a new master cylinder and that was not the problem. I don’t know if this master cylinder worked well before I installed it, but I cleaned and honed it before trying to use it. I also think that I have properly bench bleed the cylinder as well.
Everything you have described indicates that your brakes need adjusting. If the adjusters are stuck and won't turn, take them out, free them up, reassemble with antisieze and reinstall. Adjust them first and then see if anything else is necessary.
Back when I did brake jobs for a living, we replaced hundreds of master cylinders and never bench bled any of them. The Toyota manual doesn't mention it. I don't know where the concept that you have to bench bleed a MC comes from.
For me it comes from ten of my formative years spent working as an auto mechanic for the U.S. postal service. Changing master cylinders (and other things) on the road, in parking lots, and wherever else your mail delivery jeep might have been left. Bleeding the m/c before installing it often saves a lot of grief and f_____g around trying to get a good pedal on your back in mud , snow, and ditches. No nice power bleeder out there.
Also:
A quick check of the service manual for my 2001 Dodge 2500 truck reveals that the practice is indeed specified in at least one book. This one reads "A new master cylinder should be bled before installation on the vehicle" in exactly those words on page 5-30 of the brakes chapter subtitled "standard procedure - master cylinder bleeding"
I just finished a large write-up complete with plenty of pics of my 1971 all drum brake rebuilding. I have a pic of the bench bleeding setup on page 15C. I actually bled it while on the truck...
http://tinyurl.com/47zpb
A good reason to bleed the master is so you don't pump LOTS of air down the brake lines that then has to be bled out of the cylinders. Hope this helps out any all drum folks... BTW I used Jeffs site as a guide when I did mine!
