Brake problem solved!!!!
NQ Australia
Some time ago I wrote here about problems I was having with my HJ-45 disc brake conversion.
I had previously fitted 60 series front hubs and discs and left the rear brakes original.
I was having problems with the rears locking up and looked for a solution.
Most recommend replacing the whole rear axle with a 60 series, however, I fitted new small bore SWB wheel cylinders instead.
I could not get a good brake pedal, so I ended up replacing the Master cylinder and overhauling the proportioning valve, but still no pedal.
After running gallons of brake fluid thru the system and tearing out my hair, a guy in a brake shop gave me a tip!
The el cheapo chinese wheel cylinders do not have a spreader under the brake cups, like the original ones and as the cylinders are mounted vertically, air gets trapped at the top of the cylinder, that cannot be bled out!!!!!!!
The trick was to pull the top pistons and rubbers on all cylinders, top up with oil and force the rubbers and pistons down , then replace the shoes.
guess what..... I've gor a brake pedal at last!
Hope this tip saves someone else some time and money.
ronaldoB
RonaldoB said:
top up with oil and force the rubbers and pistons down , then replace the shoes.RonaldoB
You mean brake fluid I hope????
Great tip!!!
Explain this spreader under the cup? Pic shows all parts in an original front FJ40 wheel cylinder. Which one is it? The thing attached to the spring that rides against the cup?
"The thing attached to the spring that rides against the cup?'
Yup that's the bit they don't have!
The spring presses up against the rubber cup.
Some makes use a thin metal cup shaped part.
The HJ45 has two double sided cylinders mounted vertically and the bleed screw is in the middle of one, connected to the other by a pipe also in the middle. So there is no way to get air out of the top of the cylinder without filling the cyl totally with oil.
I don't really see what difference the spreaders make, but the air trap is the problem.
ronaldoB
