Brake Problem Help!
Ridgecrest, CA
I have been having a problem with my front brakes locking up. From reading previous posts, I am thinking it is the booster or a bad vacuum hookup. I have little experience with that part of the brake system. Any suggestions????
I am leaning towards a front caliper rebuild or replacement. It's the only solution. Your calipers have grunge or rust around the pistons. There is pressure put upon them to stop, and none to retract. they should retract enough to roll easily. If you don't wish to rebuild, buy rebuilt from Napa, as they come with new pads also. I try and use ome everywhere I can, but have gone the napa route on my forty with no regrets. :cool:
When you say "locking up" are you implying that the brakes are engaging as if you had your foot on the pedal, or that they are dragging?
If just dragging, then I'd agree with the caliper rebuild. There is a square seal in the caliper that is responsible for providing the "retraction" force of the piston. When you press the pedal, the gasket deforms as the piston slides out (goes from square to rhomboid), and when you take your foot off the pedal, the energy in the deformed gasket pulls the piston back ever so slightly to relieve the pressure. When the gasket gets too warn, they will fail to provide that needed pull-back, hence dragging.
By any chance did you do a lift without adjusting the LSPV?
What are you driving? Does it have ABS? Is it 4 wheel disk?
Throw us a bone Mikep!
I've got a 92 FJ80. I put installed new calipers . . . same problem. New hoses . . . same problem. The brakes engage as if the pedal was being depressed - no dragging. Sometimes to the point where the Cruiser will not go foward at all. If I get under and release fluid pressure from the bleeder nipple, she'll release and be o.k. for awhile but the problem persists . . . . . . . . .
I vote for Landtank's analysis, but only because I had a similar front brake locking experience. My front brakes locked up after driving only a couple of hundred meters from the shop.
The next day I found the problem. I'd changed my MC to an OEM and in doing so found a cut brass or bronze screw. There are two of them on the MC I was using as well as two pistons. I'd used the cut screw as a means of no waste and that had caused the problem. Replaceing it with a proper screw did the trick. I have no idea of why it did what it did but I still have no problems and it's been a couple of years since.
Kalawang
2nd Landtank's dx of MC. Had a '89 mustang that I upgraded the brakes on, new MC. After driving for 10 minutes the front brakes would lock up. Returned the MC for another and problem went away. Good luck. Nelson
x3 on master. Had the same issue on my 91. After I fixed it the booster blew out so hope you have better luck! :)
Thanks guys, what I ended up finding was contaminated brake fluid that really did a number on the master cyllinder. I replaced it and flushed the system out real good, inspecting all the calipers, etc. and everything is working as advertised now. phew
