BRAKE MASTER CYLINDER diference
does someone know the difference between
47201-60530 and 47201-60540
bedside mounting flange
low brake fluid warning switch is different.
There's a pretty thorough breakdown of all the master cylinder differences done by @cruiseroutfit a year or so ago. If you do a Google search for it I'm sure you'll find there info you're after
60530 is 2-bolt, Left/Left exit
60540 is 4-bolt, Left/Left exit
found it
i want to swap my brake booster to lexus which is bigger in size and uses wo bolt for mounting i guess will see how it works out
