brake issue with a twist
Just picked up a 94 from FL.
After I got it home, the brakes started dragging, all 4 at the same time. I figured it to be a MC problem and went ahead with the replacement with a reman unit.
Bench bled the reman (plugs in, tubes in the resivoir), and installed. I got very low pressure at the rear disks (FF rears) and nothing at all at the front, nor at the LSPV.
I figured I screwed up the bench bleed, so I pulled it and started from scratch again. No dice. I get a semi-healthy squirt at the rear, but nothing at the front or at the LSPV bleed screw. I tried 2-man, vaccum, and gravity bleeds. I have rears now, but not very strong (I am going to mod the LSPV to remain in a fixed position)
At this point I am figuring I got a crappy reman unit, and have another unit on order from the local parts jockey. I posted this up on PBB, and got a lot of interesting insights. The front wheel bearings are out of spec (about 10mm movement), but when I have it up on stands, with the tires off, it still does not allow even a trickle of fluid to the front calipers.
Any other ideas to try before I cave and take it to a specialist? It has ABS, and I am given to understand that there is a function to help purge the system of air, but I don't see how that would be relevant here, unless the front gates were stuck in the closed position somehow.
I had this exact problem and it was do to a bad line letting air into the system. In my case there was no visible leak.
Trace out the lines and look for kinks and spots that my be a problem. In my case it was some old SS lines I had put on.
This kind of concerns me. Is this a common problem with SS lines or are there some manufacturers that are better than others?
Mine were from MAF and the new ones are from Slee. Slee's are DOT approved where MAFs aren't. I don't think you will have any problems with Slee's.
Last trip to Tellico a guy rolled in with no brakes. The fluid looked like crap so I bled them and another guy ran out for a MC. Same deal they would not bleed properly. They found a kinked hard line in front of the sway bar on the front axle. Replaced the line and everything bled fine.
The problem is that air entering any one place will effect the bleeding of the whole system. So it's hard to tell for sure where the problem is but if one wheel in particular is being more difficult than the others then that's where I'd start.
Thanks Rick, I figured it was likely a problem from an inferior quality ss line.
checked all the lines for cracks/leaks, no dice. Bled the MC again, and I am gonna bleed the whole system again here inna few. I blew out the short front line, that ges from the MC to the 3 way junction, as it was looking a little tweaked. Only a tiny bit of brake fluid was in it...
I will give it a whirl again after lunch. If I don't see an improvement, I will wait for the next MC to come in the morning and do this dance again
From your desciption, you were never able to get fluid out of your LSPV. If this is still the case, take the bleeder valve off the LSPV and clean it out. The system will not bleed correctly until you get that LSPV to bleed. I don't quite understand what you mean by moding the valve so it remains in a fixed postion because it still needs to be bleed if it is moving or not. Either way, don't forget to alternate legs when bleeding the truck so that both quads get a work out. :hillbilly:
modding the LSPV arm to allow it to remain in a fixed position. It takes a bit of dialing in, but is worth it IMHO. I did it on my old Taco too.
I could hear a bit of air at the LSPV, but was not able to get any fluid no matter how much we pumped. I pick up the new MC in the morning, and will post up if I don't blow my head off first :)
I have my buddy's rollback on standby to transport it to another buddy's shop just in case!
ok, another day full of aggravation...
Bench bled the new one, put it in, same results. I poked around a bunch, and I believe I can hear air trapped in the ABS system.
Not to be defeated, I called a buddy with a rollback, loaded it up, and hauled it off to another buddy's shop.
Based on my description of the problem, we have come to 3 conclusions:
1. It is unlikely that 2 MCs in a row will have failed in the exact same way.
2. I probably introduced the air into the system.
3. I am a big idiot :)
He is going to go over the whole system, and hopefully, get it all worked out over the next couple of days. He is actually a Chebby guru, but brakes are brakes, and I trust his judgement more than my own.
Not too long ago, someone had the same problem and their problem was bleeding the ABS system also. They solved the problem by using a bleeder which used air pressure on the master cylinder reservior to push fluid through the system. You could make your own with a bicycle inner tube hose clamped over the opening. Or buy one.
Only two options left. Either the system has air trapped in it somewhere. Or there is a line letting air into the system through a messed up line (as mentioned before). Don't reach for the .45 yet. Your getting closer.
update:
MC is good, the ABS system is not allowing any pressure to leave the unit, reason unknown. No codes for the ABS in the computer, ABS light is off. No leaks or borken lines have been discovered.
He is going to bypass the ABS unit entirely. Price for new ABS unit...$1100 :eek:
you are welcome to come and find it for me :laughing:
I am not sure how a leak would have caused the initial trouble, which was all 4 disks locking up. Is there something specifc to the 80 system that I should tell him to look for?
So in the amount of experience here, what is the most common line to develop the leak?
I recently did pads on all four paws and bled the brakes, kept getting air out of the LSPV. Brakes are NOWHERE near solid and am unable to lockup all fours... Going to be riding on two wheels until I get a chance to figure things out and fix it... I was thinking it was the Master Cylinder but am glad to see the comments here and can look elsewhere.
I too think you have a leak. If it were me I would start at the alterations to the stock brake plumbing system - if you have a 5" lift I'm thinking you have alterations to the stock system...:popcorn:
The LSPV system is the weak link in the 80 series brake system in terms of its bleed-ability. It is a pain to bleed and will take a couple of hours, even with a vacuum pressured brake bleeding system.
In the end, I just took the LSPV out and the brakes are considerably tighter (also helped to rebuild the rear calipers) and way easier to bleed.
[disclaimer: do not take LSPV off unless you take full responsiblity for your and your truck's actions. I do not endorse this deletion.]
ps: I have an OEM ABS box out of a 1997 that I'd be willing to let go for cheap if the OP is interested.
Getting air out of that line narrows it down I Think. That line runs forward to a "T" right under the MC.
From my experience and the other one I saw what happens is that air enters the system when you release the brakes. Now on the next push you expel that air only to suck it back in. In my case it was the soft lines that go from the frame to the axles. There are three in total. To be honest it was an educated guess on my part. I would trace all the hard lines and look for any defects such as kinks or abrasion. If that looked OK I'd swap out the soft lines.
This is a hard failure to find as there isn't a puddle of fluid leaking out on the floor.
