Brake HELP!!! ***real time***
Hey members, I'm changing my front brake pads off a 92 fj80. The old pads are all worn out and very thin, the new pads are very thick. When pushing back the caliper pistons to accomodate the new pads, the outermost 2 pistons retracted fully to accomodate the new pad, but one of the innermost piston is stuck! It would only contract partially. Now I can't even get it to accomodate the old thin pads.
How can I get the piston to retract fully in order to accomodate the new pads or at least the old pads so I can move the truck...
I tried chisel & hammer, a lever, nothing will make that 1 piston budge!!!
TIA!!!
The piston hay have been frozen or had corrosion in cylinder wall for a while, you just see it now that you try to compact it all the way.
You an either re-build the caliper or get reman or aftermarket replacement calipers and start anew. Hit the junkyards, maybe post up in your local clubs board, check the classifieds and parting out too :meh:
Any other ideas besides getting a new caliper? The truck is stuck halfway in my garage, won't fit all the way. I can't move it until I get this issue resolved. Can't get a new caliper tonight...
you can pop the piston out and try cleaning the backside of the cup with and scotch brite pad or litghty wetsand it with a real fine sand paper to clean it up. but i would recommend rebuilding them. i think it was about 25.00 for the seals when i did mine.
any quicker ways to get this thing together so I can get it out & park it on the lawn? I can't close my garage door & it's dark out :( No brake action either...not going to drive it anywhere but just need to get it out of the garage. The old pads won't fit in anymore, I think all the pistons are stuck now. it's dinner time & i'm hungry :(
Ok, all done, I pushed one side of pistons all in, stuck in a pad on that side, reassembled the parts and moved the truck back outside. The brake was squeeling the whole way. Looks like I hammered the s*** out of the pistons, rotors & calipers. Guess it's about time to replace those parts. thanks everyone
Put the old pads back in and drive it.
Dynosoar:zilla:
Best is put a pad in front of the retracted pistons, then push on the brake to push the jammed pistons back out. Then retry shoving the pistons in squarely. My guess is you pushed a little offcenter at the wrong moment. Sorry got in on this late...
DougM
Definitly c clamp, seems to work for me. I have yet to replace pistons or seals, just use a clamp to compress, put the new pads in, bleed and go
C-clamps have always worked for me. good luck.
It's actually very easy to rebuild your calipers. The rebuild kit is cheap from Toyota and should take about an hour each on the bench. You can probably buy non oem rebuild kit as well but I've never tried.
Good luck.
