Brake fluid leak...
imyahucklbrry
“In Vino Veritas”
GA - As close to the lake as I can afford...
Changing the oil today I noticed drips on the frame.... traced it up to the surface of the booster where the brake cylinder is bolted. I do have a drop in the fluid level of course but after topping off and finishing the oil change, I took a drive... brakes work fine - not mushy at all
Am I hopefully just gonna need to replace brake cylinder? I’ve not seen any other leaks after checking... surely hoping I won’t have to replace booster as well!
Thanks ahead...
Looks like @Racer65 has a pretty close match! Never had to bleed brakes before but....... away we go ;)
Do yourself a favor and get a small jar and a clear tube that is long enough to go from the bleeder valve to the bottom of the jar on the floor. put some fluid in the bottom of the jar before bleeding. Just don't worry about wasting some fluid. You can always reuse what's in the jar if it isn't fowled by the old fluid. Of course, this is all after you read about the entire procedure.
You can doo it.
You can doo it.
And if I foul up any brake lines, I’ll know who to contact! 😎
Do you have, or do you ever contemplate adding disc brakes on your rear axle? If so, now would be the time to upgrade to a non-ABS FZJ80 master cylinder (that @Racer65 and @cruiseroutfit also sells).
Hadn’t really thought about it but.......
This? Guessing the bolt location to booster is the same? And it’s a little cheaper 😁
Yep, that one.
Bolts up perfectly to the booster. You may have to slightly bend your brake lines to fit; easy to do.
I couldn’t find anything on @cruiseroutfit site....
It's there, in fact there are two, both ADVICS and Aisin, but you gotta dig a bit to find them on Kurt's site. Easiest just to call.
Here is the page with prices, you'll have to scroll down though:
Cruiser Outfitters
Whichever master you end up using, don't forget that you'll have to check/set the pushrod length before bolting it up.
This tool (or similar) makes it real easy:
Amazon product ASIN B079QGXY55
assuming this 40 is the 82 in the OP's sig line, changing to rear disc will be different as the park brake is on the rear axle.
I bleed brakes solo, doing as @Rainman posted above, just don't let the resevoir go dry, to me brake fluid is cheap, I don't worry about wasting a pint or two
Yep... ‘82 and I just finished piecing together everything to get e-brake repaired! But if the 80 series MC is an upgrade for my truck with current brake system, this may be a good choice...
Did y’all apply RTV gasket goop when replacing MC?
Also... the leaking fluid on my booster rusted it quite some bit - I’m trying to clean it up.... would it be worth priming/painting?
Good catch; I forgot yours is an '82. Probably not worth converting to rear discs, or at least significantly more complicated to convert it.
Well, here's one last consideration before you pull the trigger on the 80-series MC: drum brakes require more residual pressure to keep the wheel cylinders from contracting between use; disc calipers require much less. IIRC, it's like 6 psi for drums and 2-3 psi for discs. The older (stock) masters either had metered residual valves in them or were designed with orifices for the correct residual pressure. The FZJ80 masters are metered for all discs, so if you used one with your stock rear drums, there might not be enough residual pressure to keep the rear wheel cylinders pumped up. @Rainman might know for sure? Maybe @cruiseroutfit ?
No need, that flange is not a sealing surface. The master cylinder has rubber pistons in it that seal it. That's how you know your master is bad. If you sealed up the flange to the booster, you might not see the fluid, and know your master was bad until your booster failed also.
If you want it to look nice.
The bad news is, when the MC fails and leaks out the back, the leaking brake fluid not only eats away the paint on the outside of the booster, but it usually flows down the pushrod into the guts of the booster. If brake fluid gets in there and stays for very long, it will corrode the inside of the booster and make it eventually fail too. I replaced both the master and the booster at the same time just to make sure, and to only have to do the job once.
@1911 ...Thanks for the help! FWIW @Racer65 website describes the 80 series MC as suitable for front disc/rear drum combination... almost placed the order but might research a little more first!
:cheers:
Did the M/C leak into the brake booster? That will cause your brake booster to fail. Brake fluid is corrosive and will deteriorate the diaphragm eventually. You may want to consider replacing the booster as well. I know they’re expensive, but if you replace both the booster and master cylinder you’ll have peace of mind knowing they have been addressed. Just a suggestion, good luck.
I think it’s safe to assume some fluid had to have made its way into the booster but my brakes worked just fine... if I hadn’t noticed the drippings on the frame when I was changing my oil, I’d still be puttering around oblivious! Changing out the booster along with the MC makes sense for sure but right now my bank account says it doesn’t make ‘cents’ so I’m gonna pray I can get some more miles out of it for now!
Thanks! 😉
Is your 40 your primary mode of transportation? If not I'd pull the master apart and see how smooth the bore looks. If good, I'd just throw in new rubber seals and keep an eye on it. Super simple and a inexpensive fix.
Thanks, I have thought about going this route...
