Brake fluid in Drum
LA, CA
My '74 has been pulling to the left when braking lately. So I pulled off the drums and the right front has brake fluid everywhere inside. That would obviously account for the pulling to the left. Now I'm trying to figure out what to do. I did some searching and a couple people mentioned this happening to them but not what was the cause and the solution.
Does it just mean I need new cylinders?
And with the fluid on the pads, does that mean I need new pads as well?
Sorry if these are stupid questions. I'm just trying to get it sorted out for a post-thanksgiving trip.
Any help would be great.
You need cylinders rebuilt or replaced. Do both sides!! Linings need replacement when exposed to break fluid...
In my experience the leak is on the same side as the direction of pull. It's amazing how some 90wt or brake fluid will make brakes grab. Be sure to check both sides.
Depending on your mindset, I usually rebuild my cylinders but, some prefer just to buy new and be done with it. As mentioned previously, check both sides, replace shoes on both sides for even wear and have fun adjusting them.....
Now might be a good time to do a little research on a front disk swap. It might not be that much more expensive than new cylinders and shoes.
Thanks guys for the answers.
A few weeks ago it was pulling to the right (same side the fluid is on) so I tried to test how much it would pull when I braked semi-hard and the brakes lock up and the cruiser went almost 90 degrees to the right. :censor:
Since then it has been pulling to the left.
I did check both sides, but the left side is fine. Didn't check the back though. I just figured it was the side where the fluid was leaking out of.
On rebuilding, looking on SOR.com I see new cylinders and individual parts. Is there a kit or a parts list anywhere? Oh, and how much work is it to rebuid vs. install new ones?
If you are a decent wrencher then do it yourself. Napa carries the rebuild kits for the cylinders. Follow my web site link for a complete lesson on rebuilding drum brakes.
I just rebuilt mine not too long ago. It isn't that hard. Coolerman has a pretty good write up about it. I got the rebuild kits from Napa. The rears cost around $8 a cylinder and the fronts were around $4. I bought a new cylinder hone as well as some brake fluid. All told, to do the rears (my fronts were still in good shape), with hone and brake fluid (I already had some sand paper) it cost around $45 to do all 4 rear cylinders. It was about the cost of buying one new cylinder.
Good luck!
Thanks for then info. I'll probably just go with new cylinders this time as I'm trying to get it in order for a little trip after thanksgiving and don't have much time.
One more question, when looking at the front brakes with the drum off I only saw one of the two cylinders expand. Both driver and passenger sides did this. Is that correct?
just remember to bleed your whole system working from the fartherest away from the master cylinder to the closest. also, with drums, you need to go in and adjust ALL your brake before you bleed them and after you adjust them, pump the brakes a few times and adjust them again if they need them.
