Brake booster
Dallas, TX
Every so often the brake pedal on my '76 FJ 40 depresses further than normal accompanied by a hissing sound. I've been told by different people that it's air in the line, or that I need to rebuild the brake booster. How do I tell which is the problem? If it's the booster, how hard is it to rebuild? I don't want to tackle something as critical as brakes if it take mechanical skills beyond my ability. Can I continue to drive it for the time being? Most of the time everything's fine, but I sometimes get an occasional mushiness.
That would be your brake booster, and they are difficult to rebuild, largely because they have high pressure springs which need to be compressed to reassemble things. A clever person might build a jig to do the job, but whether you are that person, or it is worth it to you, is another question. I just ponied up and paid SOR. About 6 months or so ago, a less expensive source of rebuilt boosters came up. I think it was CruisnGA that wrote about it. PM him for details, or try a search.
If you aren't concerned with keeping the rig 100% stock, this might work for you
I pulled a brake booster and master cylinder off of a 88 4-runner for $10. The booster just barely clears the clutch master. Adjust the plunger length, bolt up, and bleed. Good to go.
Just thought I would throw it out there.
:beer:Big Mike :beer:
when I had a booster go bad the pedal didn't get soft, it got rock hard. If you listen closely even a good booster makes a hissing sound.
I would say its the master cylinder or air not the booster
Could be that bad MC has unmasked a booster leak, too. I agree with Pimp, the loss of a booster should make braking hard.
Here's the brake booster test:
To Check Your Booster: Engine Off - press the brake pedal several times, pedal travel should not change. Start engine, pedal should move down a little and the pedal pressure will get softer. Press the brake pedal all the way down, shut off the engine, the pedal should not change position. Restart the engine, run for a minute and shut off, press the pedal several times, the pedal pressure should get harder each time.
Remember, a bad booster is a vacuum leak and will burn out your number 5 and 6 valves, so not something to leave go.
Before My master went bad all together, it did the same thing with the hisisng sound. I got a new one for about $85, installed it and bleed the brakes. Brakes work great and no more hissing sound. I have read that if you rebuild it, you might have to do that every year or so, while I would expect the new one to last a while.
Ken
So Romer, where did you buy yours? I checked both the SOR and the Man-A-Fre catalogues and websites, and they have pictures of the assembly, but you can't seem to be able to buy one. In the SOR catalogue it says something like, "Diagram is for informational purposes only".
[quote author=IDave link=board=1;threadid=13182;start=msg121591#msg121591 date=1079388845]
[/quote]
Sort of..
The springs are not that strong at all.
THe main problem is getting the two halves of the booster compressed enough to either get the retaining band around it or to turn the booster into the locked position.
The reason it is so hard is because you have to compress the rubber diaphram..
I have done a couple of things to my cruiser. Rebuilding the booster without a press was the single hardest thing I have ever had to do...
I will never do it again. If I have to pay $300 for a new booster I will think it well spent..
So. The rubber diaphragm. Thanks for pointing that out.
I have done a few drum brake boosters, they were not that bad.. I could imagine the larger dics brake (thicker) booster found on 8/75 to 9/79 40's could be a real treat tho..
I had a hard braking incident happen to me about a week ago and every since then my brake pedal will get hard. Not all the time but it seems to be happening more frequently. Does this mean that something is going wrong with my brake booster? I think that if it were the master cylinder the pedal would be spongy. Could it be the calipers?
If it is the booster, does anyone know of a good source for cheap boosters?
Booster Dewey in OR is where I got mine.
Great to deal with on the phone, haven't had a problem, good price.
He only stocks rebuild kits for the "thin" drum brake boosters, but if you need a tandem one done you can buy a Toyota rebuild kit and have it sent to him. Cruiserdan is the place to get this rebuild kit.
Mine was $135 after the core was returned I believe. This is all fairly old information.
Booster Dewey:
Power Brake Booster of Oregon 503-238-8882
Do a search under my name and brake booster. I went through this on my '76. Your booster is starting to go. My '76 did this exact thing. The one way valve at the inside oriface is leaking and intermittantly leaking away all your vacuum. That's why the pedal gets hard to push. You will notice this especially when offroading-If you stall out on a steep hill and need very heavy brake pressure to keep from rolling backwards. Then it gets scary. I got the rebuild parts from CDan and the rebuild done by Booster Dewey. It turned out great. You will spend a few more $$ but your brakes are well worth it. I got a note from Booster Dewey that the Toyota rebuild kit is very high quality and includes everything you need. C Dan really helped me out by getting all the parts from Japan.
Booster Dewey is the man. Mine came back nicely finished, perfect function within 3 days. Free bag of nuts with it too.
John
