Wrapping up knuckle rebuild and new F & R brakes. Bled the rear brakes just fine. Went to bleed the front and I cannot get any fluid to come out of the bleeder screw and noticed that the pistons were not moving. Suspected blocked line so I took them apart and blew them all out with compressed air, no blockage.
Went to bleed again and still no fluid coming out of the front bleeder screws and no movement on the pistons. WTH? Turned the vehicle to the on position just in case the ABS requires power, still nothing.
So, I disconnected the lines at the calipers to see if they are bad and no fluid will come out when brakes are depressed.
My buddy pushing the brakes said that when I cracked the bleeder he felt no change in the brake pedal.
Disconnected the lines at the ABS module and fluid came out when pedal was depressed. I am lost. Moving in a few days and stressed about getting this back on the road. Help is appreciated!
