Brake bleeding on the cheap..
Calgary, Alberta - Canada
It is more of a brake flushing..
Found this site while lurking on the web. Haven't tried it myself but I think may worth a shot given the difficulty of bleeding the brake system on the 80.
bleeder
Just one concern about this set-up is the volume of brake fluid it takes to fill the container high enough to work. I'd think that you may want to open a can of fluid and set the opened can in the bottom of the sprayer with the discharge tube inserted in the can neck. Just an idea..
This is exactly how I made mine, although I made a few improvements. Mine has a nice pressure gauge so I can keep track and not go too high, I never go over 15 psi, as I don't want to blow up the reservoir. I also used a larger sprayer. I also used a chunk of 3/8" aluminum plate for the piece that sits on top of the reservoir, I made a gasket out of old truck inner tube. Finally I added a fitting so I can use shop air to pressurize the tank, regulated down to 15 psi with an air brush regulator.
Here it is, setup and working on my bench:
I know I've used that bleeder dozens of times now, it works great. But, in retrospect, I spent so much time and effort on it, I would just buy the Motive bleeder if I was doing it again.
I'm with Pin_Head, I didn't realize the normal method was expensive or hard.
The cheap and easy way to bleed brakes is the "two-person" method. It has the advantage of also being very reliable. All it takes is a little brake fluid and 10 minutes.
x3 If you can't get a helper, I've done it with a 2x4 jammed between the pedal and the seat.
For a one man operation the pressure brake bleeder is a time saver... I made one once upon a time from a small garden sprayer, it leaked... Recently I purchased the motive-bleeder with adapters, should have saved the money and just bought it the first time around...
If you really want to do it alone, hose clamp three inch piece of hose to cyl/caliper to be bled clamp a tire vavle stem next cap side toward cyl/caliper another piece of hose into two liter bottle. Remove resevoir cap, fill, pump slowly, fill, pump slowly, fill, do on each cyl/caliper, furthest from master first. Check to make sure works, have a beer.
I have a Motive power bleeder and I prefer using my cheap $5 one man brake bleeder tool from Pep Boys. It's basically a clear tube w/ a one way check valve on one end.
the Speed Bleeder
Several people over at TundraSolutions use these and say they work great for one person brake bleeding. I am getting a set for the Tundra and the Land Cruiser.
Question - So one of these is used at each wheel, correct?
Yes, or you could buy one and move it to each wheel that needs bled. I would just get 4 of them, then just bleed in the same pattern as usual (furthest to closest to the master cylinder)
5. You forgot the LSPV. ;)
Harbor Freight has a few products that may be of use. I have the one in the second link and it has worked well for me. It does require an air compressor though
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Avoid the unit in the first link. I purchased one today and it is worthless. In fact, I think I have more air now than before using it.....
What Size Speed Bleeder ?
Yep, speedbleeders are slick! No more two person action, just have to watch the fluid level.
Does anyone know what size "Speed Bleeder" I should buy? 1973 FJ55...
NAPA has the following:
Mfg Part Number:639560
Size:10 mm x 1.0 Thread
Mfg Part Number:639590
Size:3/8" - 24 Thread
Mfg Part Number:639530
Size:5/16" - 24 Thread
I presume that the 10mm is the beast since the other two are standard and not metric. Anyone????
