Bowfin Rack accessories??
California
does anyone know if the Prinsu rack accessories fit on the Bowfin Rack. i want to mount a hi lift and possibly awning. Thanks.
I would think any of the Prinsu stuff for mounting on the crossbars would work, since they’re the same type of bar. However, speaking from experience, I would highly recommend the Bowfin awning rack. It’s extremely solid. The other advantage with the t slots on both racks is that if you like the DIY aspect, you can make or adapt a lot of things to easily attach, so you could probably pick up a variety of hi lift mounts and make them work.
Bowfin makes awing brackets along with RTT brackets. I have both. The crass bars can be bought on Tnuts.com along with different bolts and attachemnt to make your own. They are 10 series i believe and I think prinsu uses the same bars so it should interchange but I have no personal experience with fitting the actual prinsu acc on a bowfin. I do know the from runner stuff won't work
The RTT brackets have attach to the bars and have an offset hole for running a bolt through. It would be very easy of make a high lift attachment
