Bosch iBooster Brackets for 60/80 Series – Tested in Moab, Ready to Go
anyone care the share their 60 series booster install experience with pics if you can
Should be essentially the same as installing in an 80, except perhaps a little easier without having to work around the 1FZ intake.
Finally got around installing mine this weekend
Out with the old
In with the new
@torfab kit is great!
Removing the stock booster nuts under the driver’s footwell, then yanking it past the intake and spaghetti of brake lines, not so much.
It is no boat anchor, but it is definitely better than stock. Not gonna lie, I was expecting a bit more, but I do have a feeling I need to re bleed it again.
Pedal feel is very nice and light, like a brand new car.
Ive been considering deleting the ABS lately after reading a lot of comments about how much better braking is after.
We will see, for now, this will do!
Did mine. Used ABS relay circuit wires for 12v hot and 12v IGN. @thatcabledude mentioned that it was likely post OEM fuses. Ran 40 and 5 amp fuses right at ABS connector area regardless. Will report out if any issues. ABS deleted. Ran a proportional valve for rear circuit. Running an ABS master cylinder. Stops amazing! Dialing in the prop valve. Great upgrade for sure! Had ordered an ABS master but it’s taking a while to get here, together with other hardlines and axle way for non ABS. Will clean up hardlines at master at a later time. Will report out if there is a better improvement with non ABS master. It’s still amazing without it!
