Bosal vs. Magnaflow...you decide.
Got the manifolds and Y pipe installed today. Absolutely no issues with fitment. It couldn't have gone back together any easier. Even the OEM bracket holding one of the upper Y pipes fit right together. Now to find someone to do the rest of the exhaust over the frame.
View attachment 909441 View attachment 909442 View attachment 909443 View attachment 909444 View attachment 909445
@iptman can you post a shot looking straight up at the cat flange or maybe just take a quick look? Im trying to find out if i have room before my exhaust goes up and over the frame to put in a flex pipe. I wont know exactly where the magnaflow will end up untill it is mounted though. It looks like it ends at the middle of the transmission cross member? I have a thread going here, thanks!
How's this? My slider is kind of in the way.
Also, here's the drawing of the flange I got from Magnaflow in case there's someone out there who can machine these things for us rather than use crappy fitting off the shelf flanges.
Thanks @iptman , I was trying to find a point of reference and your pics help a lot, not much room down there for sure. I did purchase a few flanges. Nothing really mates well though, did you use a flat gasket or OEM donut type? I'm going with the v band, Hope it works out, I'm just winging it.
There's a flat gasket in now. I tried to put an OEM gasket in recently when I had the Y pipe off and it wouldn't seal so I went back to the generic flat gasket.
After 12 years the Magnaflow unit needs to be replaced. Check out the O2 senor studs...or what's left of them. And I never drove my 80 when salt was on the streets around here.
I can beat that...entire o2 sensor bung rotted off....or more correctly the weld rotted away.
But you're in Pa, he's in Cali. What you guys do to cars in Pa is cruel: you guys can rot galvinised stainless steel like butter. There's no better place to have a car than Cali. Pa to Ca is chaulk and cheese.
That rust is amazing considering.
