Still having issues. I just rebuilt the master cylinder. Brakes work fine. If I bleed the system, it’s perfect for a few days. Then the noise and alarm return. I believe a possibility is the o’ring, spring, and silencer tube between the pump and accumulator.
I’m calling my local dealership to see if they stock them seperate.
I'm really interested to see if that works.
I just did repaired a bad brake issue near point of failure, and was going to do job piece by piece, with rebuild and used parts. To see what would solve issues and try to save some coin. But owner just wanted new.
This one had varying times in test (IG switch off and pump pedal than time run time of motor). Colder the longer the run times in test. The less used the long the time. Pedal pressure would drop off new 40 pumps. In new low mile or new booster assembly 25 times until pedal falls off.
This one also had bubbling in reservoir while screeching at times. Again more so when cold.
