12mmx1.5, iirc.
The three speed transmissions(lower bolts thread into transmission housing) and flywheel housings were coarse thread and not fine like the four speed flywheel housings.
Need a couple bolts Mike?
If so, stop down Friday or Saturday and you can have them.
12mm x 1.5 x 35mm
Click HERE to download a spread sheet that contains most of the nuts,bolts,screws for a 1971 FJ40 Cruiser. If you see some that are not there let me know and I will try to add them.![]()
Found another bolt spec I had but forgot to post...
Transmission to Bell Housing Bolts
4 12mm x 1.25 x 35mm. Split Washer Only. 17mm Head but 19mm will fit. Stamped 6.
