Body Panel question
JDNs78FJ40
Draper Utah
Will be starting my build thread soon, but getting some things in place first.
So I have the usual rust spots on my 1978 FJ40. Does anyone have any ideas for these areas? It’s where the hardtop meets the body. The quarter panels are in good shape. Any source for these pieces.
Those don't look too bad.
Probably easiest to patch some 16 guage in there.
Agree with thecrazygreek. Hit it with a wire wheel(cup brush). Less aggressive method, buy some Permetex rust disolving gel, slather it on, scrub with a stiff nylon bristle brush, or wire. Might take a few rounds, but will remove all the rust for a closer inspection. The disolver gel used to be called “Naval Jelly” Looks structurally sound and will be covered if a hardtop is going back on. If soft top, you can fill the pits, smooth it out, then paint.
You could also use a paintable rust “converter”. Permatex makes some of that too. Guessing that’s not the route you want though:beer:
Did someone slice through that tub rail? You can weld that up. Multiple tack welds then grind smooth. The heat might bubble your paint. Are you re-painting this rig?
I made patch panels when I did mine, wasn't too difficult. Make cardboard templates then transfer that to steel. Weld in carefully because its real easy to end up chasing holes for half a day.
D
No, that slice is just where the rounded corner meets the straight part. They slip in to one another. Thanks for the input
