Body Mount Shims
Near Junk
OK - I am re-aligning the Aqualu tub and OEM cowl fitment this weekend in hopes of fixing some panel alignment issues on my '76 FJ40.
Question is what to use for body mount shims as I work to get all sitting level and even. I've checked around at some local auto stores and don't really see anything that would work well. Should I just buy another body mount kit and grind/shave them down as needed? Is there some other hard rubber material I could use (besides sneaker soles!)?
AndrewT
body mounts
I am using round polyurethane stock that I cut custom for the desired mount.
The polyurethane stock came from MSC. For 36 inches the price is about $125 but that will make your mounts and leave a little for screw up.
www.mscdirect.com
Part # 31998719
90A Durometer Polyurethane rod - 2" x 36"
Check it out and see if its something that you might want to use...working for me and another buddy used it on his ride (two years?) with no problems that I am aware of.
Travis
The OEM stuff looks like fire hose, some kind of rubberized canvas.
Maybe the local Fire House? We used to use old hose from the FS pumpers for Axe guards. I know they keep the old hose for stuff like that.
Heavylift - that MSC place is genius. Thx - ordered a 48" length of 1.5" diameter poly tubing. Should work fine for my needs since I have the mounts there already and just need extra for shims.
Appreciate the help.
AndrewT
AndrewT
You can still get hard rubber shims in different thicknesses from the dealership. At least you could less than 2 years ago.
