Body lift problems
South west utah
So the previous owner of my 91 installed a 2 inch body lift. I almost took it off when I got the rig 5 years ago because I have heard bad things about them. I did some research here on mud and found a lot of people using them in 80's with no problems so I figured I would leave it on. Fast forward 5 years and I got a new noise on my last trip. Upon inspection I found the culprit.
Only this one body mount has decided to give out. I will hopefully update this thread after a day or two of welding and reinforcing with pictures of my repair. I wanted to post this for others who are thinking of using a body lift. They definitely have their disadvantages.
Is rust an issue with your truck?
Did you ever get some air and landed hard?
It's the first time I see one of those bad outcomes.
Haha, I don't recall getting air but I have been known to mob lol. , I was in a minor wreck 2 years ago on the other side of the truck. The truck is 100% rust free and from las Vegas originally. Although the broken metal was kind of black. The spacers on the lift are aluminum so I am wondering if maybe some kind of galvanic corrosion phenomenom weakened the tub.
sounds like this dissimilar metals to me
I have aluminum pucks on mine, so I need to keep track of that.
thank you for posting
I would say the difference between the diameter of the lift puck and the OEM body mount is a large part of the contribution to the cracking and depression.
Diameter of the puck looks smaller Prabably more of an issue than material. If the bolt was loose the mount could rub down to the bare material
Then corrosion becomes an issue.
Update: here is the hole after I cleaned it up and some pieces fell out
Here are the pieces the fell out l, they don't look rusted but they are all black
I got a piece of metal cut and welded now so it should be good. I measured my aluminum pucks and they are 2 1/2" tall. I think I will plan on taking them all off and cut them down to 1 1/2" and try to find a 1/2" rubber to sit on top of the aluminum.
