blown/over pressurized power steering pump????
West Virginia
Hey, new to the forum and new to me lx owner, so any and all help would be much appreciated. Was out playing in deep snow and had front and rear lockers engaged, putting alot of stress on the pump obviously, anyways sawed the wheel back and forth a few times to get unstuck. I was back on the road in just a few seconds and after unlocking front and rear realized the power steering wasnt working right, thought at first maybe everything was full of snow and ice. Got out to check and oil dripping all over everything underneath the front end. There's a 1/4" hole on the backside of power steering pump near the driver fender. It gushes fluid out almost as fast as you can pour it in. I cant find any info on what that hole is in the pump and i cant see it without taking the pump off. Is it a pressure relief that's stuck?? Or just a drain to tell you when a seal is blown out, which would mean a new pump or rebuild. I figure I blew the guts outa the pump but wanna make sure before I just go and rebuild it. Again, Thanks for any input.
its possible that you were low on fluid and the sawing back and forth enveloped air into the fluid possibly creating a cavitation. If you held it on lock this will also produce more pressure in the system. Not sure how the hole happened, I don't think there should be a hole on the back side... Others may weigh in at this point as I've exhausted my (probably incorrect) knowledge on this system.
lexus power steering.webp Hey thanks for the response, and sorry for the crappy picture, was outside in the dark and thats the best i could get. I plan on pulling it off this weekend aint got time durin the week cause of work. Anyways, its the lil hole i tried to circle, it literally just runs right out almost as soon as your pour it it.
it looks like a plug blew out. Recalling from memory, there is a plug that seals off a internal passage in the pump. That is not a serviceable part, that I'm aware
Bigcat, by not serviceable, you mean that plug can't be purchased for replacement, meaning I just gonna have to get a new complete pump??
My definition on Non Serviceable means you can't buy a replacement piece part. In this case, if it's that plug on the rear end of the pump, then I haven't seen a plug or seal in the exploded parts view or reseal kit.
John
