Meanwhile, some 3UR valve springs fail out of the blue, nuking a piston and usually the head and block.
It’s still an incredibly small percentage of the total units sold.
I’m not sure where people got the idea that engine issues in a Landcruiser were ever “unheard of.” 80-series 1FZ-FE very commonly had head gasket issues. I forget which inline-6 turbodiesel had bad bottom end bearings. The RoW 4.5TD is notorious for dust killing the turbos and piston rings. Not a LC but Toyotas 3.slow in the 4Runner.. hell even the worshipped 22RE will use the timing chain to chew a hole from the crank case into the coolant circuit.
The 2UZ was a solid engine but wouldn’t do much of what a 3UR will (towing, mileage) and the vast majority of those 3URs will do it without head gasket problems. No this won’t make someone facing the cost of repair feel any better, but this sky is falling s*** is getting old.
ANY vehicle over 100k is a risk, some at far less mileage than that. End of the day, a 200-series is less risk than many vehicles. Don’t like the remaining risk? Choose a different vehicle.
Edit: and trying to be constructive here, if anyone is worried about their head gasket Used Oil Analysis is a proven effective way to get a heads up on even minuscule amounts of coolant in the oil. You could plausibly catch a HG issue before it damages the block or head, vastly reducing the cost of repair.
Might be worth considering with your oil changes if all of this is keeping you up at night.
