Black 100 Series Build
This is really the only photo I have with the Turbomac wheels. Stock AHC, pinch welds cut back and still rubbing. They were really close to clearing the pinch welds but under full compression they rubbed on the fenders.
gonna bump this thread, @Ryan Smith how are these wheels working out?
They unfortunately still bump/rub a bit when I hit bumps. I had my guy hammer the finders out a bit to create more room. I'm also looking into bump stop options
I did some testing with a 285/70 BFg at. They run smaller than the MTs you have of the same size. Pinch weld touches when the wheel is turned, and rear slee bumper touches at full compression but not by much.
@ENGINE er and @Ryan Smith
Are you guys still running your wheels? Any updates? I'm currently waiting on a set of the fifteen 52 analog's with the same specs you guys are running.
I also ordered a set of 315's for them...but after reading the clearance issues I think im in trouble.
manage to fit those wheels? because i just ordered some and started to do some research and now i might be in the same boat
Just finished AHC Delete and looking at new wheels and tires. I was looking at Fifteen52's and my search brought me to this fee.
@ENGINE er @toyocruisers How are those fifteen52's working out? I am about to order a set for my lx470 that has an IM 2" lift. No heavy offloading just beaches and sidewalks. Wondering if the BFG's fit better. I've got 275/70/r18's on there now with no rub. Didnt rub before the lift either
I have a 2.5 inch dobinson lift on mine. I am running 265 70 17s which is almost a 32 inch tire and i havnt had any problems with the fender touching the tire. I had to trim some plastic at the pinch weld otherwise it would catch when turning. If you have a stock bumper any size tire bigger than mine you will have to trim the front bumper or buy an aftermarket one, i did put a single 33 inch tire on at one point to see how it would work out but i forget. i do plan on putting bigger tires on one day but i didnt feel like doing the mods, if you did have any problems with the fender touching you could also add bumpstops.
as shown above in the pictures im sure you could get away with the 285 BFg with the fifteen 52 wheels if you hammered back the pinch weld
