BJ74 Parting out
Status
Not open for further replies.
Greendale B.C Canada
89 JDM BJ74 5spd Black w/grey special edition interior.
13B-T H55F not available at this time.
Everything else is.
Light roll over. Rear corners of FRP/ rear quarters and hood have damage.
Top edge of small rear door has a ding, Large door is good. $300 for set.
FRP would make for a good pop top project or pick up type top.
All glass is in tact and available. $100 a piece except for windshield which goes with the frame.
Complete PTO winch set up SOLD
Brush bar SOLD
RH front door SOLD
33x10.50 muds SOLD
4x 15" aluminum rims w/ 3.25" backspacing SOLD
Dash board accessory meter and pad available (Altimeter, in/out temp display) SOLD
LSD 4.11 drum rear Full floating axle SOLD
Front axle w/4.11 diff, knuckles done recently. SOLD
Virtually new OEM Voltage regulator SOLD
New OEM Speedo Cable $80
Running board set with brackets SOLD
Front signal lamp RH $50
Rear Left Tail lamp assy SOLD
Safari Snorkel and Airbox SOLD
Aux Lamps SOLD
Complete headlamp washer set up includes Washer jug/ 24v motor, tubing, switch, front valence w/ sprayer nozzles SOLD
Front inner fender skirts SOLD
Grille SOLD
Toyota grille emblem SOLD
Turbo Emblem w/ clip SOLD
Windshield frame with glass SOLD
Front LH outer fenders SOLD
Front RH upper fender SOLD
Front inner fenders SOLD
Front RH outer lower fender SOLD
Front rad support panel $200
24v Power Mirrors ( RHD specific) SOLD
Good Carpet set SOLD
Good rear bumper $100
Rear Interior panels SOLD
Ashtray SOLD
Cig lighter SOLD
Rear View mirror SOLD
FRP top emblems SOLD
Fuel tank skid plate SOLD
Fuel Tank $300
Fuel filler pipe SOLD
Center Console SOLD
Rear Heater w24v blower $100
More pics
Replied
I have plans for the 13B-T H55F
Sale pending on the Snork.
I'll have to pull the covers and take a look.
They are the funky striped cloth to match the door panels.
Roll bar assy is unscathed. This 74 went upside down but somehow only damaged the top of the hood and the back end of the FRP/ rear quarter corners. Amazing really.
$300 for the roll bar assy with all the associated interior trim bits and mounting hardware.
Roll bar will be too large to go UPS/Fedex. Packaged it will be about 60"long 48"tall and 12" wide and 80ish lbs.
Will have to go by truck or something.
I'm not interested in pulling the glass out of the frame. Too great a chance of
cracking it. It goes with the frame.
S
Shoot.. Sorry, I didn't realize you didn't have one yet.. I would have let you know for sure.
Here are some more pics after I took the pressure washer to her..
All sheet metal is available except the Right front door which is already sold.
Tub has the typical BJ74 rust spots at lower rocker between door and wheel arch, some rust in rear tail lamp buckets. Front end metal looks good, hood is stuffed as you can see in the pics.
Wheels and tires cleaned up really nicely.
4x 33x10.5 15" BFG KMs w/ 50-60% tread $350
4x Aluminum 15" wheels w/ correct 40/60/70 Cruiser backspacing
look like about 7" width. $350
Or rims and tires together for $600
Status
