Hello,
I started my power steering mod, some might have notices another post where I was asking about the pressure vs return port. I got some great replies, went out and actually measured the ports. The pressure port is 1MM smaller than the return port. I will post some flicks following the install/mod:
Before:
Manual box removed:
Rivet heads cut off, holes drilled 1/2 thru to allow punch and sledge to do their magic!
New mount bolted into place and safety wired:
'nuther view:
View showing steering rod and misc hose and line clamps in place
Shot of a honda powersteering cooler from eBay $12.00
U.S. Radiator triple pass, 4 row, "optima" desert cooler radiator:
Power steering pump is from a stock 3B, I will have a new pressure lin made at the local hose shop, will post some flicks after the hose is made.
Hola
eric
Before:
Manual box removed:
'nuther view:
Hola
eric
