I've been searching, but I'm confused about what I'm actually going to need.
The Birfs are toast in my 80, as well as the drive-flanges. This is on a '92 with 180,000 miles. I have a major clunk which has worsened in the last 3000 miles of driving. I also have clicking when turning.
I've got the axle seal rebuild kit from cruiser dan, new wheel bearings, and some outer pinion bearings for the diff.
I'm going to rebuild the whole front, and re-gear to 4:56 while I'm at it.
If I go with Longfields;
- do I switch to the deeper splined flange from the '94 and up Cruisers?
-should I go with the whole kit, including inner and outers (axles) from BL? I wonder this since using just Chromo outers, can cause problems with the stock inners?
-If I go with 30 spline axles, do I need a new carrier and spiders?
At this rate, I may end up selling the MJ and do the FJ up right.
In the future, I will be going the LT-1 V-8 route when the 3FE gets tired. So I guess going with the Chromos would be wise option at this point.
If this is a repeat question, please point me in the right direction.
Thanks.
Thanks.
