I purchased new longfields about a month ago and finally got around to the installation on Saturday. To my amazement the longfields were a half inch shorter then my stock 27 spline 76 fj40 birfs. Did I order the wrong longfields, are there different lengths,are the mini truck birfs different in length from fj birfs? All the splines matched up fine but the length was off, any help?
fender washer and a metric bolt in the end....or (even smarter), find a set of minitruck Aisin lockouts to replace the Warn's you likely have installed - much stronger, and the body is 3/8" shorter so you can use the stock clip
either works dandy tho, I've run both ways without issue.
As Mace said, that's normal. The 76-78 used a unique longer fine spline birf and only those years. Every other birf 79 and later is shorter, with the dimensions of the Longfield. ie all 40s, all 60's all 62's and all minitrucks. The birfs you have now will be too short to fit the c-clip, and the work around is a fender washer on the end of the birf and bolting the fenderwasher to the end of the birf.
You probably know this, but your axle housing will have to be ground a bit to fit the bell of the birfield.
You are right-they are practically unobtainium. When I did my conversion on my '76 (swapped complete FJ60 knuckles out) The old parts were snapped right up. I had one spare long birf left and gave it to one of my friend with a '77 and told him to keep it in a safe place since there wern't any more and SOR wants $250 each.
See, the part I find funny about that is that the later birfield will fit just fine in the earlier axle. The only reason to keep running the smaller ones is because they're cheaper.
I personally haven't paid more than $30 (shipping not included), and I've got five of them right now.
