I've recently acquired a 96 LX. It's not triple locked but it has low miles and is in great shape. Drivetrain works as it should, with no obvious symptoms of impending issues.
I am rebuilding the front knuckles. One side went smoothly. I knew I had an issue on the second side, gear lube mixed with grease coming from the back of the knuckle, felt/wiper area. I get things taken apart and find an inner axle seal damaged (pic) and an elongated axle sleeve behind the seal. Additionally there is some damage to the inner knuckle where the axle seal sat as well as some scoring on the inner knuckle just under the upper trunnion bearing and related scoring on the birfield itself.
I plan on replacing the birfield. Im concerned about the damage to the inner knuckle. Is this something I need to worry about? What's the best way to deal with the damage? Any thoughts on what might cause a catastrophic failure of the axle seal like that?
