Birfield HELP On The Road !!!!
North Front Range, CO
I made it to DesMoines IA on vacation and I think my Newfield birfield is failing.:crybaby:
It is more than just poping, its making a "kerr-chunk" sound when you move and turn. I can see the left tire bind up and release when it happens.
It is fine when I drive and not turn the wheel.
When I drive and make a turn it makes the metal grinding noise.
It just started when I exited off I80 to get a motel so I only drove several hundred yards to the motel with the noise.
I have about 500 mi to go to my campground in central WI.
I wont be wheeling so what ever I do I don't need 4 wheel drive.
I will be there the weekend and return 1200 mi to GJ CO.
What are my options so I can keep going on my vacation?
Should I remove the front drive shaft?
Remove the birf and plug the hole?
What should I do, the wife doesn't want to spend my vacation in IA:frown:
As far as plugging the hole, I guess if you leave the other axle in, you gotta plug it with something. If you pulled both axles and the drive shaft, your front diff wouldn't be turning--you could just drain the gear oil. Right? I would probably be more comfortable with this solution rather than trusting my plug to hold all the lube in the diff.
You've got a CDL siwtch, no?
If you don't, can't you get it to lock by putting it in low, pulling the plug from the t-case, then putting it back in high. Somebody else better verify this, though.
If you pulled out both axles and the drive shaft, there wouldn't be anything turning the front diff--it would just be sitting in the housing all by its lonesome--the tires would just be rotating on the spindles. Under those conditions I can't see why you couldn't completely drain the diff.
Landtoy- where are you now?
I have a set of locking hubs you could borrow until you get to a place for a proper fix. slap on the locking hubs, drop the drive shaft and you shouldn't be turning the diff after that, right?
Anyway- I'm in Fort dodge, which is between Des Moines and your destination- I could meet you on the interstate or somewhere else this afternoon/ evening. I'll PM you my phone if you need it.
Doc, I am in Des Moines right now but need to go to Madsion Wi to get a camper then go to Babcock WI to camp.
I will try the flange idea first.
Anyplace in DesMoines sell locking hubs, I have often though about getting them for this reason.
I have the Newfield and had to change the flange to a different flange as the Newfield was not the same size as my 94 birf.
How would I know what lockout I need?
So you have the newer flange? If so the birfield would be too long to work with a locking hub. You need and earlier birfield (shorter).
I have a few earlier ones, but I an ATL :(
Good luck!
I can't see why just pulling the flanges and sealing the hubs with plastic bags and rubber bands wouldn't work great (also pulling the drive shaft).
With the axles still in you don't have to worry about oil moving out of the diff.
The axles and diff wont turn.
You don't have to tear into the knuckles.
You don't have to extract any greasy oily parts.
The plastic bags should do just fine--it's not like you're trying to contain oil--just keep the grease in the hubs clean and uncontaminated.
I wouldn't worry about the locking hubs.
No need to drain the diff. Minimal oil will get to the end of the spindle, unless your inner axle seals completely failed.
There is the small issue of the birfield having to swivel when you turn, but unless it is broke and binding, it should not be an issue.
If you have the birfields with the longer splines you might have issues with certain drive flanges. The end of the birfield contacts the plastic red locking tab (on the Aisins) and will turn it or destroy it.
I have the aisins, so they are of no help to you landtoy- sorry!
Sounds like the plastic sack idea is the easiest so far. Go with that. If you need anything on the way- you have my #'s.
I put duck tape over the hub then a bag and more tape.
I am glad I still have the center caps as that will hold things.
BIG THANKS:flipoff2:
If you don't here from me again, it means I got eaten by a bear at the campground....
The duck tape inplace of the flanges works. I have many hundreds of miles no problem.....with the front axle that is...
With the front driveshaft off I now have a leaking seal from the front output shaft of the t-case, will post new topic for it.
