Birfield Carnage!
Here's my own personal opinion from having done about a dozen birf repacks. Not nearly as many as some, but I've seen a few. Some with completely wiped out axle seals that had been leaking for a long time.
That birf was put together dry. period. Non-moly grease would still be in there. Even chassis grease would be a burnt nasty mess. It the wiper was dry, it didn't wash out. If the axle seal was bad, the birf would have been full of oil.
What little is left in there might just be what was left in the bell after cleaning. Or, as TLCgrappler suggests, there was some non-high temp grease put in the bell. I can just see it not getting done at all easier than it getting done partly. Especially if the FSM doesn't specify packing the birf. There are a lot of Toyota mechanics that don't work on LCs much if ever.
The fact that it lasted 37,000 miles I'd chalk up to the lack of contaminants. No water or dirt to take out the birf. There really isn't a ton of friction in the birf all of the time. It's not like a roller bearing thats constantly rolling under load.
The FSM is very clear on this; moly grease in the tulip, the cage, the balls, and the knuckle cavity.
I'll post the relevant FSM pages this evening.
-B-
-B-
I was going from the info posted in post 29. I don't have a FSM, I have an ALLDATA. Mostly it's exactly the same except for how it's organized.
You and Raven are correct. The FSM only mentions filling the knuckle 3/4 full. No mention of the birfield joint. Interesting.
-B-
-B-
Now I'm terrified. I've only got 1/4th of a liter of grease in mine and I'm pretty sure that isn't going to fill it 3/4ths. Looks like I need to estimate how much to add and do so as soon as possible.
Kalawang
-B-
Actually, it does mention it, although not in the detail that some of our pictoral tutorials availble here do. From the 96 FSM
On page SA 16, after cleaning and inspecting the removed birf parts
"(g) Coat the joint inner parts and outer shaft inside with molybdenum
disulpfide lithium base grease, NLGI No.2
(h) Install the inner race in the cage through the large opening.
(i) Position the protruding end of the inner race toward the
wide side of the cage.
(j) Assemble the cage and inner race to the outer shaft by
fitting the 2 large openings in the cage against the protruding
parts of the outer shaft.
And
(l) Fit in the inner race and cage and install the 6 bearing
balls in the outer shaft (See step (c)).
(m) Pack molybdenum disulpfide lithium base grease, NLGI
No.2 in the outer shaft
(n) Install a new snap ring on the inner shaft.
I have often thought that specification critical comments should be noted somehow, perhaps with a "crying face" instead of a smiley, to show the regret you'll have if you don't follow the directions. Of course, if you're a mechanic, the regret will be your customer's, and not (directly)yours.
