Birf help
Iowa
I am trying to get the passenger side birf to break down and am having no luck at all. I started out using a longer then stated piece of abs plastic and the worked just fine on the drivers side but just didn't seem to be able to get at it on the passenger side. Switched to a piece of 2" galvanized black pipe and am working this thing and it wont go. Joint spins freely still. drive shaft is locked up tight in the up against the joint and isn't spinning freely. Just seems like the snap ring wont let go. Famous last words are that it looked easy on youtube with one or two hits breaking it free. I am at about 40 and am scared I'm going to mess it up.
Any ideas? I know someone said a pipe wrench but didn't wont to tear it up.
Help!!!!
Keep slamming it! It took me hours and my arms were sore but it did work eventually.
Chuck the axle shaft in a stout vise and then get a helper and both of you strike the star of the CV joint simultaneously with a brass drift and a hammer. If you can't get someone to help try hitting the star on alternate sides.
What are you slamming the pipe on? I had a hard time popping a birf off once while slamming the PVC pipe on a railroad tie, switched to my driveway asphalt and that did it. Also, you did remove the snap ring from the star side of the birf?
Are you trying to separate the birf from shaft? Lift the birf in the pipe holding the pipe and the top of the birf stub shaft, keep it pressured against the center of the star. Lift it up above your head and smash it down onto concrete might take multiple strikes
As said above, slam it harder! Make sure you have some rags stuffed into the bottom of the pipe so the shaft doesn't slam into the concrete when it breaks free.
Yeah, I have been using a piece of galvanized pipe. Smashed it into a board. No rings visible that I can see. Did the drivers side the same way and it separated after two hits. Worried I will take a chunk of the concrete in my garage out as hard as I was going. It was punching circles out of the towel I had down to begin with so I switched to the wood block.
Push the rag up into the pipe and slam it hard down on to a piece of plywood on the concrete driveway. That way both the shaft and the driveway are protected and you don't have to worry about breaking anything.
I alway find it's easier if the pipe is held solid in a vise or a helper holding it. Any bouncing softenens the jarring. At one point I had a hole drilled in my solid wood shop table for just such things. One or two drops and it was off.
Like others have said, slamming it on concrete seems to be best, but make sure you have s bunch of rags to cushion it. Having something like plywood or whatever just seems to cushion the blows in my opinion. My personal trick was to swear at it like sailor with tourettes while doing this. This one is a pain in the butt though.
