billie 7100 question
Reno, NV
So I've got a question about Bilstein 7100's, is the remote resevoir absolutely neccessary? The schrader valve ones go for about $130, and the RR goes for $180 apiece. Just wondering if on an 80 the extra expense is worth it.
Thanks,
Jack
I read on a website about shocks somewhere that gas charged shocks are not necessary unless you are doing high speed stuff like desert racing and a good quality hydraulic shocks are good for most off road adventures.
I could be wrong and i'm sure someone will correct me with some cold hard facts, but i'd save some bucks and go Hydraulic unless your gonna be racing your 80.
Jim
The remote res affords a shorter body which means longer compression (up) travel. This pics should help..
I went the 7100 route for a couple of reasons.
1- rebuildable, I will have this shock for ever.
2- Valveable, Can change the valving @ will.
3- Short body and good travel.
That being said, they are big bucks and not a straight bolt on.
So far Im very happy with mine.
ken
I also went with them for that reason you can get a 12" travel shock that is the length of a 10".
Some body hep me! I don't /haven't found any reference to shorter body more travel/longer stroke "THEORY". In a 10" shock body there can only exist room for a 10" piston stroke, remote reservoir or not. You can get 2" more shock extension by adding a 2" extension and that only extends the piston and not the travel. Here again I may be wrong but I still say gas charged high dollar remote reservoir is money best used for lockers or other suspension upgrades. BTW i did look at the pictures.
Hope I don't sound argumentative, just need to be edumacated.
Jim
All monotube shocks are high pressure. Usually from 250 to 300 psi. There is a "floating piston" that separates the shock oil from the high pressure gas (usually nitrogen). The reason for the high pressure is to reduce the likelihood of oil cavitation. This helps to reduce oil foaming and shock fade.
A remote reservoir shock allows the floating piston and gas charge to move into the reservoir. This lets the "valve piston" and piston rod travel farther in the shock body.
The reason the 7100 shocks have the schrader valve is because they are rebuildable and need a way to be re-pressurized after they are rebuilt. Also this allows the gas pressure to be varied as a tuning variable along with adjusting the shock valving.
The resevoir add to the volume of oil for better cooling resulting in less shock fade. After running your truck down a long wash board road you will be glad you have the extra volume.
Go for the resevoir you shocks will perform better, last longer by staying cooler.
Did you get another 80 Jack?
As Ken already answered, yes.:grinpimp:
Now Mr. Ken, I will bothering you quite extensively on your part numbers and well pretty much everything when it comes time to get mine ordered and installed.
Thanks everyone for the help, I had not realized the packaging was the reason for the RR versions.
Also when it comes to the hydro vs. gas, when you are running down a 70 mile washboard valley in a fully loaded vehicle, the gas makes a whole lot of sense. I'm not rockcrawling, I'm desert hauling:D
Another benefit to the 7100's is the valving, hard to get those numbers on any thing else that I have been able to find.
Jack
