Bikini top - rail install....
Southern Ontario
Looks to me like the Besttop rail for my bikini top is longer than the windshield.
Anyone else experience this ? I assume a quick chop will solve the problem -- does the shorter length affect the actual top ? Do you just live with it ?
Thanks,
Mark
how much longer? my rail is about 1-1.25" longer than the actual bikini on each side... I see no harm in the rail being too long
Well - with the rail being too long, the curves that are supposed to line up with the windshield would not align.
But yes, looks as if taking an inch/inch and a half from the middle would fix everything up!
Just a suggestion.
I'm moving my rail from the windshield to the front hoop of my roll cage so I can fold the windshield down and still have a bikini top on.
You might want to consider this.
I just put the rail on (BestTop) my FJ40 and it is about 1 inch longer and works great. I drilled new holes in it so I could use the existing holes w/ nuts inside and didn't have to drill into my window frame.
Before cutting you may want to check the width of the bikini top itself because mine goes the whole width of the longer rails.
I was told that it is supposed to be longer to work with the doors, but haven't tried it yet. Who knows...
HTH,
Brian
If you shorten the rail, you'll find the plastic insert at the front of the top will spit out the sides. I just let it hang and it gives me some extra overhang over the doors. Looks ok and works fine.
*edit" : yeah, what he said ^
I called the bestop people and asked why is it longer than one I purchase 3 years earlier. They said i could cut the ends to center it. Mine top fits perfectly after I cut mine.
