About the only difference I can think of is Toyota went to a drive by wire throttle in 1992-1995 models.
About the only difference I can think of is Toyota went to a drive by wire throttle in 1992-1995 models. The extra cab 4cyls will have a weaker g58 5spd and chain driven transfer case as opposed to the much better w56 and gear driven case on the std cab models. Look for models with manual hubs instead of autos and ADD. If you live in a part of the country where rust is an issue check for frame rust at the rear spring hanger, especailly behind the gas tank.
I can't think of anything else.
Thanks! , ya i hears the K&N filters are troublesome, i will probley order an oem one
. Stick with oem parts, oem is the way it was designed and ment to do if you want it to last reall long, toyota style. unless you want a crazy 4x4
GET PICTURES IF SO!! You could also run a dry/wet compression test to see whats up with your 4cyl's cylanders (like any other average vehicle). Were is the rust exactly?All the trucks were good, just STAY AWAY from the 3.0 (worst thing toyota EVER made!)
